[Gdal-dev] Some Locale Work
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 31 14:49:12 EST 2007
Folks,
At the request of a client, I have done some work to improve locale support
in GDAL. In particular:
o to make the world file parser support a mixture of locale use in the
numbers.
o to ensure the well known text parsing and composition work properly
regardless of locale, including the EPSG file reading.
I think these particulars are working pretty well. I also fixed a variety
of similar issues with regard to OGRSpatialReference.
To help test, I have extended the GDAL test suite python scripts to support
the --locale commandline switch. So for instance doing:
run_test.py --locale de_DE.utf8
will run the test suite in the german locale. This currently shows problems
with PROJ.4 (due to proj.4 not having non-locale specific parsing), in some
ogr formats (especially related to wkt geometry, and gml geometry), and
some problems in gdrivers - especially with the WCS driver.
I'm going to continue to wittle away at these as time permits, and I hope
to setup a buildbot instance at some point that actually runs the test suite
in a "numerically dangerous" locale in the future.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
