[Gdal-dev] support for python 2.5.1
John Cartwright John.C.Cartwright at noaa.gov
Mon Jul 2 11:32:10 EDT 2007
Thanks Howard and Frank for your prompt replies.  I've found that
although the compile works fine, but when I try to use the gdal python
bindings, I get the following:
/extra/contrib/lib/python2.5.1/site-packages/gdal.py:191:
RuntimeWarning: Python C API version mismatch for module _gdal: This
Python has API version 1013, module _gdal has version 1012.
  import _gdal
I've had the same experience on both RHEL 3, and Mac OS X 10.4.  Can you
tell from the above what I might be doing wrong?
Thanks again for your help!
-- john
Howard Butler wrote:
> John,
> <http://trac.osgeo.org/gdal/ticket/1379> was one issue that existed
> with the next-gen bindings and Python 2.5 that should now be cleaned
> up with 1.4.2.  I believe the old bindings should work without
> modification.
> Howard
> On Jul 2, 2007, at 9:19 AM, Frank Warmerdam wrote:
>> John Cartwright wrote:
>>> Hello,
>>> Should I expect gdal 1.4.2 to work w/ python 2.5.x?
>> John,
>> I am not aware of any problems but nothing is certain till you try it.
>> At worst it should only require a few build tweaks to get it working
>> I would hope.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | President OSGeo,
>> http://osgeo.org
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
