[Gdal-dev] Re: support for python 2.5.1
Kurt Schwehr schwehr at ccom.unh.edu
Mon Jul 2 16:23:13 EDT 2007
Works for me on PPC Mac OSX 10.4.10 using fink unstable gdal (I did
the update to the fink package yesterday).   Looks like where ever
you got gdal from or where you built it had a different version of
python that was picked up.  Perhaps you have multi pythons around and
an older one if being found by configure?
-kurt
% fink list gdal
i   gdal                      1.4.2-1001          Raster/Vector
Geospatial Format Translator
i   gdal-dev                  1.4.2-1001          GDAL/OGR
development headers
i   gdal-python-py25          1.4.2-1001          GDAL Python Module
i   gdal-shlibs               1.4.2-1001          GDAL/OGR shared
libraries
% ipython
Python 2.5.1 (r251:54863, Jun  7 2007, 18:40:41)
IPython 0.8.1 -- An enhanced Interactive Python.
In [1]: import _gdal
> From: John Cartwright <John.C.Cartwright at noaa.gov>
> Subject: Re: [Gdal-dev] support for python 2.5.1
> Thanks Howard and Frank for your prompt replies.  I've found that
> although the compile works fine, but when I try to use the gdal python
> bindings, I get the following:
> /extra/contrib/lib/python2.5.1/site-packages/gdal.py:191:
> RuntimeWarning: Python C API version mismatch for module _gdal: This
> Python has API version 1013, module _gdal has version 1012.
>   import _gdal
> I've had the same experience on both RHEL 3, and Mac OS X 10.4.
> Can you
> tell from the above what I might be doing wrong?
> Thanks again for your help!
> -- john
> Howard Butler wrote:
>> John,
>> <http://trac.osgeo.org/gdal/ticket/1379> was one issue that existed
>> with the next-gen bindings and Python 2.5 that should now be cleaned
>> up with 1.4.2.  I believe the old bindings should work without
>> modification.
>> Howard
>> On Jul 2, 2007, at 9:19 AM, Frank Warmerdam wrote:
>>> John Cartwright wrote:
>>>> Hello,
>>>> Should I expect gdal 1.4.2 to work w/ python 2.5.x?
>>> John,
>>> I am not aware of any problems but nothing is certain till you
>>> try it.
>>> At worst it should only require a few build tweaks to get it working
>>> I would hope.
>>> Best regards,
>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>> warmerdam at pobox.com
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush    | President OSGeo,
>>> http://osgeo.org
>>> Gdal-dev mailing list
>>> Gdal-dev at lists.maptools.org
>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
> End of Gdal-dev Digest, Vol 38, Issue 1
