[Gdal-dev] Building with profile directed optimization
Seth Price
seth at pricepages.org
Sat Jul 7 16:25:07 EDT 2007
I'm trying to build GDAL with GCC 4's profile directed optimization
and I'm hitting some problems. It would be awesome if this sort of
optimization could be incorperated into the build process. :) I'll
outline the steps I'm going through and hopefully someone can point
out what I'm doing wrong.
I start by adding '-fprofile-generate' to all flags. I'm not using
any optimization here because it mangles the output code a bit and is
not recommended.
export CXXFLAGS="-fprofile-generate"
export CPPFLAGS="-fprofile-generate"
export CFLAGS="-fprofile-generate"
export LDFLAGS="-fprofile-generate -lgcov"
./configure && make
Here is where the first problem occurs, this command needs to be
altered to add the "-lgcov", then everything goes smooth.
/bin/sh /usr/local/gdal/gdal-1.4.2/libtool --mode=link g++ -O1 -
fprofile-generate -ljpeg -ltiff -lpng -lz -ldl -lgcov -L/usr/lib -
lcurl -lssl -lcrypto -lz -o libgdal.la /usr/local/gdal/gdal-1.4.2/
frmts/o/*.lo /usr/local/gdal/gdal-1.4.2/gcore/*.lo /usr/local/gdal/
gdal-1.4.2/port/*.lo /usr/local/gdal/gdal-1.4.2/alg/*.lo /usr/local/
gdal/gdal-1.4.2/ogr/ogrsf_frmts/o/*.lo ./ogr/ogrgeometryfactory.lo ./
ogr/ogrpoint.lo ./ogr/ogrcurve.lo ./ogr/ogrlinestring.lo ./ogr/
ogrlinearring.lo ./ogr/ogrpolygon.lo ./ogr/ogrutils.lo ./ogr/
ogrgeometry.lo ./ogr/ogrgeometrycollection.lo ./ogr/
ogrmultipolygon.lo ./ogr/ogrsurface.lo ./ogr/ogrmultipoint.lo ./ogr/
ogrmultilinestring.lo ./ogr/ogr_api.lo ./ogr/ogrfeature.lo ./ogr/
ogrfeaturedefn.lo ./ogr/ogrfeaturequery.lo ./ogr/ogrfeaturestyle.lo ./
ogr/ogrfielddefn.lo ./ogr/ogrspatialreference.lo ./ogr/
ogr_srsnode.lo ./ogr/ogr_srs_proj4.lo ./ogr/ogr_fromepsg.lo ./ogr/
ogrct.lo ./ogr/ogr_opt.lo ./ogr/ogr_srs_esri.lo ./ogr/
ogr_srs_pci.lo ./ogr/ogr_srs_usgs.lo ./ogr/ogr_srs_dict.lo ./ogr/
ogr_srs_panorama.lo ./ogr/swq.lo ./ogr/ogr_srs_validate.lo ./ogr/
ogr_srs_xml.lo ./ogr/ograssemblepolygon.lo ./ogr/ogr2gmlgeometry.lo ./
ogr/gml2ogrgeometry.lo \
-rpath /usr/local/lib \
-no-undefined \
-version-info 12:2:11
Then I 'sudo make install' the libraries and run './exercise.sh' to
hit all the code I use often. After that the profiling files have
been produced. I can't use 'make clean' because it will erase the
profiling files, so I use the following commands:
sudo find . -name \*.o -exec rm {} ";"
sudo find . -name \*.lo -exec rm {} ";"
sudo find . -name \*.a -exec rm {} ";"
sudo find . -name \*.la -exec rm {} ";"
sudo find . -name \*.lai -exec rm {} ";"
sudo find . -name \*.dylib -exec rm {} ";"
Now is the problem I'm stuck on. I can compile with '-fprofile-use',
but I can't add any optimization (even '-O1') because I immediately
get this error:
/bin/sh /usr/local/gdal/gdal-1.4.2/libtool --mode=compile g++ -Wall -
O1 -fprofile-use -DOGR_ENABLED -O1 -fprofile-use -I/usr/local/gdal/
gdal-1.4.2/port -c -o cpl_conv.o cpl_conv.cpp
g++ -Wall -O1 -fprofile-use -DOGR_ENABLED -O1 -fprofile-use -I/usr/
local/gdal/gdal-1.4.2/port -c cpl_conv.cpp -fno-common -DPIC -
o .libs/cpl_conv.o
cpl_conv.cpp: In function 'void* CPLRealloc(void*, size_t)':
cpl_conv.cpp:194: error: corrupted profile info: number of executions
for edge 6-7 thought to be -93808
for edge 6--2 thought to be 320155
make[1]: *** [cpl_conv.o] Error 1
make: *** [port-target] Error 2
Does anyone have an idea what is causing this? If I add '-O1' to the
first compile, I still get this error, so I don't think it's a
mismatch. Ideas on how to proceed?
~Seth
