[Gdal-dev] memory leaks in MITAB driver
Richard Matsunaga
richard.matsunaga at waypointinfo.com
Mon Jul 9 14:25:30 EDT 2007
I've fixed a few memory leaks in the MITAB driver that have been plaguing me
lately. Hopefully someone more qualified than I can validate these changes
and submit them into the code base.
Regards,
Richard
Index: /ogr/ogrsf_frmts/mitab/mitab_feature.cpp
--- /ogr/ogrsf_frmts/mitab/mitab_feature.cpp (revision 11729)
+++ /ogr/ogrsf_frmts/mitab/mitab_feature.cpp (working copy)
@@ -7813,6 +7813,12 @@
+ if (poStyleMgr)
+ delete poStyleMgr;
+ if (poStylePart)
+ delete poStylePart;
return;
@@ -7997,7 +8003,13 @@
SetBrushFGColor((GInt32)nBrushColor);
- return;
+ if (poStyleMgr)
+ if (poStylePart)
+ return;
@@ -8281,6 +8293,14 @@
nSymbolColor = strtol(pszSymbolColor, NULL, 16);
SetSymbolColor((GInt32)nSymbolColor);
+ if (poStyleMgr)
+ if (poStylePart)
return;
Index: /ogr/ogrsf_frmts/mitab/mitab_imapinfofile.cpp
--- /ogr/ogrsf_frmts/mitab/mitab_imapinfofile.cpp (revision 11728)
+++ /ogr/ogrsf_frmts/mitab/mitab_imapinfofile.cpp (working copy)
@@ -281,6 +281,7 @@
TABPoint *poTABPointFeature = NULL;
TABRegion *poTABRegionFeature = NULL;
TABPolyline *poTABPolylineFeature = NULL;
+ const char *styleString = NULL;
* MITAB won't accept new features unless they are in a type derived
@@ -300,11 +301,11 @@
case wkbPoint:
poTABFeature = new TABPoint(poFeature->GetDefnRef());
- if(poFeature->GetStyleString())
+ styleString = poFeature->GetStyleString();
+ if(styleString)
poTABPointFeature = (TABPoint*)poTABFeature;
- poTABPointFeature->SetSymbolFromStyleString(
- poFeature->GetStyleString());
+ poTABPointFeature->SetSymbolFromStyleString(styleString);
break;
@@ -313,14 +314,13 @@
case wkbPolygon:
case wkbMultiPolygon:
poTABFeature = new TABRegion(poFeature->GetDefnRef());
+ if(styleString)
poTABRegionFeature = (TABRegion*)poTABFeature;
- poTABRegionFeature->SetPenFromStyleString(
+ poTABRegionFeature->SetPenFromStyleString(styleString);
- poTABRegionFeature->SetBrushFromStyleString(
+ poTABRegionFeature->SetBrushFromStyleString(styleString);
break;
@@ -329,11 +329,11 @@
case wkbLineString:
case wkbMultiLineString:
poTABFeature = new TABPolyline(poFeature->GetDefnRef());
+ if(styleString)
poTABPolylineFeature = (TABPolyline*)poTABFeature;
- poTABPolylineFeature->SetPenFromStyleString(
+ poTABPolylineFeature->SetPenFromStyleString(styleString);
break;
@@ -381,6 +381,8 @@
eErr = OGRERR_FAILURE;
delete poTABFeature;
+ if (styleString != NULL)
+ CPLFree((void *)styleString);
return eErr;
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070709/d256ab1d/attachment.html
