[Gdal-dev] C# Dataset not calling GDALClose()?
Richard Matsunaga
richard.matsunaga at waypointinfo.com
Wed Jul 11 09:49:39 EDT 2007
Thanks Tamas, I didn't look deep enough to see what was happening in the C++
code for Dataset.
My problem is that our application is an ASP.NET web site and as soon as a
class instantiates a GDAL or OGR object, the GDAL dll gets locked and is
only released after some long period of idle time or if iisreset is called.
This makes updating GDAL (or just republishing the entire website) a bit of
a pain. I was initially worried that there may be a memory leak in there as
well, but that seems to not be the case.
The problem is easily reproduced using NUnit as well. Any test case that
uses a GDAL resource will lock the GDAL dll as well.
I just tried calling Ogr.RegisterAll() and it is the cause of the lock on
the dll. There seems to be no way of releasing resources initialized by
RegisterAll(). Not surprisingly, this behaviour is also flagged as a memory
leak (albeit a small one) by DevPartner when using OGR in an application.
Cheers,
Richard
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
> Tamas Szekeres
> Sent: July 11, 2007 6:42 AM
> To: Richard Matsunaga
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] C# Dataset not calling GDALClose()?
> Richard,
> OGR_DS_Destroy doesn't handle if the datasource is shared so
> I consider OGRReleaseDataSource is the proper method to use.
> Could you describe your issue in more detail?
> Best regards,
> Tamas
> 2007/7/11, Richard Matsunaga <richard.matsunaga at waypointinfo.com>:
> > On a related note, I see that the Dispose() method for DataSource
> > ultimately calls the OGRReleaseDataSource() method.
> Shouldn't this be
> > calling
> > OGR_DS_Destroy() instead? The latter method is the one I
> used in the
> > hand-rolled C# wrapper class.
> > Richard
> > ________________________________
> > [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Richard
> > Matsunaga
> > Sent: July 10, 2007 11:59 PM
> > To: gdal-dev at lists.maptools.org
> > Subject: [Gdal-dev] C# Dataset not calling GDALClose()?
> > Tamas,
> > Shouldn't Dataset.Dispose() be calling GDALClose()? I'm trying to
> > track down a resource issue and wondering if this is a
> potential problem?
> > Thanks,
> > Richard
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
