[Gdal-dev] compile problems re: GIF on RHEL 5/64-bit platform
Doug_Newcomb at fws.gov
Wed Jul 11 13:32:08 EDT 2007
John,
I usually add /usr/local/lib to /etc/ld.so.conf . I've noticed that
when I've compiled things from source on Centos that I have to disable
selinux and run /sbin/ldconfig after I install ( Proj4, geos, ecw, etc)
before it will allow the new libraries to be seen in the library path.
I've been thinking about building rpms and seeing how that goes ( In my
copious spare time) to avoid that issue. Long term, I probably just need
to wrap my head around selinux configuration.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
I left my signature file in /dev/null
John Cartwright
<John.C.Cartwrigh
t at noaa.gov> To
Sent by: gdal-dev at lists.maptools.org
gdal-dev-bounces@ cc
lists.maptools.or
g Subject
Re: [Gdal-dev] compile problems re:
07/11/2007 11:46
AM
Hi Doug,
thanks for the suggestion. I was able to get gdal to compile using a
modified egif_lib.c that Frank supplied. However, strangely the gdal
executables don't seem to be able to find some of the shared libraries
even though the directory is listed in the LD_LIBRARY_PATH variable. Did
you have any issues like this? It may be a problem specific to RHEL 5.
Thanks again!
--john
Doug_Newcomb at fws.gov wrote:
> John,
> If it helps, I've just compiled 1.4.2 on Centos 5 64-bit using the
> external gif libraries and it finished compilation using the system
> giflib-devel-4.1.3-7.1.el5.1. Frank, what are the advantages of using
the
> internal gif library over the external gif library ?
> Doug
> Doug Newcomb
> USFWS
> Raleigh, NC
Interior.
> Frank Warmerdam
> <warmerdam at pobox.
> com>
To
> Sent by: John Cartwright
> gdal-dev-bounces@ <John.C.Cartwright at noaa.gov>
> lists.maptools.or
cc
> g gdal-dev at lists.maptools.org
Subject
re:
> 07/10/2007 04:31 GIF on RHEL 5/64-bit platform
> PM
> John Cartwright wrote:
>> Hello All,
>> I'm trying to compile 1.4.2 on a RHEL 5 platform. I configured using
>> "--with-gif=internal", but during the compilation process I'm stopped
by:
>> gcc -c -I/extra/contrib/src/gdal-1.4.2/port
>> -I/extra/contrib/src/gdal-1.4.2/gcore
>> -I/extra/contrib/src/gdal-1.4.2/alg -I/extra/contrib/src/gdal-1.4.2/ogr
>> -I/extra/contrib/src/gdal-1.4.2/ogr/ogrsf_frmts -DOGR_ENABLED
>> -Df2cFortran -D_POSIX_SOURCE -I/extra/contrib/src/gdal-1.4.2/port
>> -I/extra/contrib/netcdf-3.6.2 -I/extra/contrib/netcdf-3.6.2/include
>> -Ilibungif -Wall -O2 libungif/egif_lib.c -fPIC -DPIC
>> -o../o/.libs/egif_lib.o
>> libungif/egif_lib.c: In function 'EGifOpenFileName':
>> libungif/egif_lib.c:79: error: 'S_IREAD' undeclared (first use in this
>> function)
>> libungif/egif_lib.c:79: error: (Each undeclared identifier is reported
>> only once
>> libungif/egif_lib.c:79: error: for each function it appears in.)
>> libungif/egif_lib.c:79: error: 'S_IWRITE' undeclared (first use in this
>> function)
> John,
> Could you try substituting:
http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/gif/libungif/egif_lib.c?format=raw
> for gdal/frmts/gif/libungif/egif_lib.c and see if that builds? If so,
> please file a bug against GDAL and I'll make sure this fix makes it into
> the 1.4 branch too. I'm guessing that RHEL 5 is removing some deprecated
> macros, like S_IREAD and S_IWRITE as part of a cleanup-and-modernize
> effort.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
