[Gdal-dev] Problem importing Arc Binary Grid data
Thu Jul 12 12:14:37 EDT 2007
Decarlo, Thomas R. (LARC-B702)[NCI INFORMATION SYSTEMS] wrote:
> I’ve been given a directory full of DEM data that I’m supposed to import
> for use in an osgdem terrain model build. I think, based on the file
> names, that the data is in Arc/Info Binary Grid format (AIG). The
> problem is that I don’t think I was given everything that I need to
> interpret the data. The contents of the directory looks like this:
> 07/11/2007  10:07 AM    <DIR>          .
> 07/11/2007  10:07 AM    <DIR>          ..
> 10/26/2006  11:21 AM               104 tdenv.adf
> 10/26/2006  11:21 AM        15,135,552 tedg.adf
> 10/26/2006  11:21 AM             4,624 thul.adf
> 10/26/2006  11:21 AM           157,792 tmsk.adf
> 10/26/2006  11:21 AM               116 tmsx.adf
> 10/26/2006  11:21 AM        15,135,552 tnod.adf
> 10/26/2006  11:21 AM        10,090,416 tnxy.adf
> 10/26/2006  11:21 AM         2,522,604 tnz.adf
> I’m using FWTools v1.3.4, and I don’t see how to import this stuff. Does
> anyone out there know what this is and how I can bring it into Imagine
> format? The GDAL Supported Formats page says that AIG format uses the
> *.adf extension and is supported for reading, but I cannot even get a
> successful gdalinfo from any of these adf files.
Thom,
I think this looks more like an arc/info binary vector coverage ... likely
specifically a TIN.  Grids would look more like:
warmerda at amd64[50]% ls -l demgrd/
total 216
-rw-r--r--  1 warmerda users     32 2006-07-13 06:36 dblbnd.adf
-rw-r--r--  1 warmerda users    308 2006-07-13 06:36 hdr.adf
-rw-r--r--  1 warmerda users    165 2006-07-13 06:36 log
-rw-r--r--  1 warmerda users     32 2006-07-13 06:36 sta.adf
-rw-r--r--  1 warmerda users   7112 2006-07-13 06:36 vat.adf
-rw-r--r--  1 warmerda users 182586 2006-07-13 06:36 w001001.adf
-rw-r--r--  1 warmerda users   4596 2006-07-13 06:36 w001001x.adf
Vector coverages might be supported by ogr (try ogrinfo on the
directory name) but I *think* the vector coverage driver requires
an associate (parallel) info directory.  If you don't have that,
you might have problems reading the data.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
