[Gdal-dev] gdal_translate Basic Usage / UTM to latlong
Tim Osborn tosborn at sbcglobal.net
Fri Jul 13 15:37:01 EDT 2007
OK...this is what's going on.....
I'm pretty sure the image is projected in the Wisconsin Transverse Mercator
coordinate system WTM83.  You can read about it at
http://www.dnr.state.wi.us/maps/gis/wtm8391.html.  They list the parameters
there and an email address you can request a prj file.  WTM83 is not the
same as regular old UTM NAD83.  The EPSG number code for WTM83 is 3070 and
the code for WTM83(HARN) is 3071.
Here are the parameters for WTM83:
Map Projection Name: Transverse Mercator
Longitude of Central Meridian: -90 degrees West
Scale Factor at Central Meridian: 0.9996
Latitude of Projection Origin: 0 degrees
False Easting: 520,000
False Northing: -4,480,000
Unit: Meter
Using these parameters, your expected lat long for the center of the image
and what gdalinfo reports are very close.
Tim
View this message in context: http://www.nabble.com/gdal_translate-Basic-Usage---UTM-to-latlong-tf4065198.html#a11584290
Sent from the GDAL - Dev mailing list archive at Nabble.com.
