[Gdal-dev] gdalwarp: target image extents are recognised wrong
Michael84 michael.timo.welsch at gmx.de
Mon Jul 16 13:58:05 EDT 2007
Hello,
I'm using gdalwarp to warp an image of 15862P x 19548L from UTM to Lat/Long.
gdalwarp -s_srs "+proj=UTM +zone=32 +datum=WGS84" -t_srs "+proj=latlong
+datum=WGS84" utm.tif latlong.tif
Gdalwarp then creates an image of 20491P x 15138L, instead of 15862P x
19548L or something with the same apect ratio!!! What could be the reason
for it ?
I know that providing the target size is one solution to this problem, but
it is not quite nice...
View this message in context: http://www.nabble.com/gdalwarp%3A-target-image-extents-are-recognised-wrong-tf4090047.html#a11627232
Sent from the GDAL - Dev mailing list archive at Nabble.com.
