[Gdal-dev] Possible enhanced NetCDF support in GDAL
A.Th.C. Hulst hulst at argoss.nl
Wed Jul 18 10:27:16 EDT 2007
On Wednesday 18 July 2007 08:59:54 A.Th.C. Hulst wrote:
> I'll send you a personal e-mail with the URL and mapfile when I have
> everything working properly.
You can see the speed of the current netcdf driver on
http://mapserver.argoss.nl. Looks good to me.
It's configured with the map file I enclosed.
Regards,
Sander
MAP
  EXTENT 0 -78 360 78
  IMAGECOLOR 255 255 255
  IMAGETYPE PNG
  SHAPEPATH "/var/www/mapserver/data/"
  SIZE 1024 768
  STATUS ON
  UNITS DD
  NAME "RASTERTEST"
  OUTPUTFORMAT
    NAME "gif"
    MIMETYPE "image/gif"
    DRIVER "GD/GIF"
    EXTENSION "gif"
    IMAGEMODE "PC256"
    TRANSPARENT FALSE
  END
  OUTPUTFORMAT
    NAME jpeg
    DRIVER "GD/JPEG"
    MIMETYPE "image/jpeg"
    IMAGEMODE RGB
    EXTENSION "jpg"
  END
  PROJECTION
    "init=epsg:4326"
  END
  WEB
    IMAGEPATH "/var/www/mapserver/html/tmp/"
    IMAGEURL "/tmp/"
    LOG "/var/www/mapserver/log/rastertest.log"
      METADATA
        "wms_srs" "EPSG:28992 EPSG:4326 EPSG:32631"
        "wms_onlineresource"  "http://mapserver.argoss.nl/cgi-bin/mapserv?map=gbp_wms.map&"
        "wms_abstract"  "Test raster data"
        "wms_accessconstraints" "none"
        "wms_context_version" "1.1.1"
        "wms_title" "ARGOSS WMS Server"
        "wms_feature_info_mime_type" "text/html"
      END
    QUERYFORMAT text/html
    LEGENDFORMAT text/html
    BROWSEFORMAT text/html
    TEMPLATE "/var/www/mapserver/html/templates/global.html"
  END
 LAYER
    NAME "Hs"
    DATA "netCDF:/var/www/mapserver/data/windwave/ww3_output.nc:sign_wave_height"
    PROCESSING "SCALE=0,7.5"
    PROCESSING "SCALE_BUCKETS=100"
    PROCESSING "BANDS=1"
    TYPE RASTER
    STATUS ON
    OFFSITE 0 0 0
  END
END
