[Gdal-dev] What are georeferenced coordinates?
Kent Eschenberg
eschenbe at psc.edu
Thu Jul 19 17:23:00 EDT 2007
Thanks! Here's the command and results:
$ gdal_translate -projwin -121 36 -113 31 ./R/relief.tif test.tif
Input file size is 25740, 17280
Computed -srcwin 11313 5194 0 0 from projected window.
-srcwin 11313 5194 0 0 falls outside raster size of 25740x17280
or is otherwise illegal
That should be an area covering southern California. I'm supplying the output
from gdalinfo as an attached file since it is long.
TIA!
kent
Ethan Alpert wrote:
> The output of gdalinfo on your source image file as well as your command
> line invocation of gdal_translate would be useful in determining your
> problem.
> -e
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Kent
> Eschenberg
> Sent: Thursday, July 19, 2007 2:52 PM
> To: GDAL
> Subject: [Gdal-dev] What are georeferenced coordinates?
> What are georeferenced coordinates? I can't find a definition in any of
> the
> GDAL documents. I would guess they are longitude and latitude.
> I'm trying to use the "-projwin" option for gdal_translate with valid
> longitude
> and latitude. But this always fails saying they are outside the bounds
> of the
> input image. "-srcwin" works as expected.
> "gdal_translate --version" yields "GDAL 1.4.2.0, released 2007/06/27".
> I'm
> using a Redhat Fedora Core 5 system.
> TIA!
> Kent
Driver: GTiff/GeoTIFF
Size is 25740, 17280
Coordinate System is:
PROJCS["TIFF 6.0, GeoTIFF Revision 1.0",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",45],
PARAMETER["longitude_of_center",-100],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-2262900.000000000000000,1038900.000000000000000)
Pixel Size = (200.000000000000000,-200.000000000000000)
Metadata:
AREA_OR_POINT=Point
TIFFTAG_IMAGEDESCRIPTION=USA Lower 48 elevation tints
TIFFTAG_SOFTWARE=Arc/Info
TIFFTAG_XRESOLUTION=0.0049999999
TIFFTAG_YRESOLUTION=0.0049999999
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left (-2262900.000, 1038900.000) (132d43'42.07"W, 50d 2'25.05"N)
Lower Left (-2262900.000,-2417100.000) (121d28'10.03"W, 20d35'58.80"N)
Upper Right ( 2885100.000, 1038900.000) ( 59d31'54.76"W, 47d31'42.21"N)
Lower Right ( 2885100.000,-2417100.000) ( 72d47'14.96"W, 19d 4'10.39"N)
Center ( 311100.000, -689100.000) ( 96d25'32.42"W, 38d43'59.57"N)
Band 1 Block=25740x1 Type=Byte, ColorInterp=Red
Band 2 Block=25740x1 Type=Byte, ColorInterp=Green
Band 3 Block=25740x1 Type=Byte, ColorInterp=Blue
