[Gdal-dev] Measured Values for Shapefile read & write
Craig Hunter craigrthunter at gmail.com
Tue Jul 24 12:25:06 EDT 2007
I performed a hack to the OGR source in order to read and write shapefiles
with measured values.  If others may find this of value, I'll work on a
patch?
Also, the SDE driver only provides read access.  Is there some technical or
proprietary issues with performing write access to SDE? or has this not been
developed due to a lack of interest?
Thanks,
Craig Hunter.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070724/977d55ca/attachment.html
