[Gdal-dev] Measured Values for Shapefile read & write
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Jul 24 18:28:45 EDT 2007
On Tuesday 24 July 2007 12:32, Nelson, Dean wrote:
> Yes, I was projecting to a WSG84 from a Lambert_Azimuthal_Equal_Area
> projection (as far as I can tell) See the "[Gdal-dev] Is ogr2ogr the
> tool to use?" thread.
> Regards,
> Dean Nelson
> Enterprise Electronics Corp
If you are projecting across datums, then you might want to check that you
installed GDAL/OGR in such a way that the NADGRIDS files were included. If
you are outside of North America, then I am not sure how to go about this.
http://proj.maptools.org/
Cheers,
Dylan
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Dylan
> Beaudette
> Sent: Tuesday, July 24, 2007 1:53 PM
> To: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] Measured Values for Shapefile read & write
> Sounds like there was some kind of NADGRID mixup.... ? where you
> projecting
> across datums?
> cheers,
> Dylan
> On Tuesday 24 July 2007 11:34, Nelson, Dean wrote:
> > Craig,
> > We would like our product to ingest any type of shape file (projected
> > or
> > lat/lon) and be able to run with it. However, as in the "[Gdal-dev] Is
> > ogr2ogr the tool to use?" thread, I have some shapefile data from the
> > USGS/Hydro1k project that is projected from a point and all of the
> > values in the polygons are x,y values. I needed to convert to a
> Lat/Lon
> > shapefile. I did it via ogr2ogr and the resulting output was placed
> 17km
> > north of reality.
> > I was looking for a kludgy fudge factor ;-)
> > Regards,
> > Dean Nelson
> > From: Craig Hunter [mailto:craigrthunter at gmail.com]
> > Sent: Tuesday, July 24, 2007 12:52 PM
> > To: Nelson, Dean
> > Cc: gdal-dev at lists.maptools.org
> write
> > Dean,
> > Are you referring to an offset, in the sense you have a point on
> > a line and you want to project it 100 meters off to the left side (90
> > degrees) of the line? In that case, no, but I'm pretty sure that can
> > already be performed with the ogr library as it is now.
> > I'm referring to measured values (M-values) that are included in
> > the geometry and can be used for dynamic segmentation.
> > (Sorry for the repeated message, I left the mailing list off my
> > initial reply)
> > On 7/24/07, Nelson, Dean <dean.nelson at eecradar.com> wrote:
> > Craig,
> > Would this be like a projected shape file (i.e. x,y off
> > of a median) ?
> > Regards,
> > Dean Nelson
> > [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Craig Hunter
> > Sent: Tuesday, July 24, 2007 11:25 AM
> > Subject: [Gdal-dev] Measured Values for
> > Hi,
> > I performed a hack to the OGR source in order to
> > read and write shapefiles with measured values. If others may find
> this
> > of value, I'll work on a patch?
> > Also, the SDE driver only provides read access.
> > Is there some technical or proprietary issues with performing write
> > access to SDE? or has this not been developed due to a lack of
> interest?
> > Thanks,
> > Craig Hunter.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
