[Gdal-dev] Reproject with Mapserver vs gdalwarp
Jan Hartmann j.l.h.hartmann at uva.nl
Wed Jul 25 09:54:30 EDT 2007
Frank, is there any reason why Gdal doesn't use the epsg-file? Wouldn't
it make things easier if it did? In my experience, this double
administration can cause problems that are very hard to detect.
Even better of course is Howard Butler's web-based approach:
http://lists.maptools.org/pipermail/gdal-dev/2007-July/013641.html
Jan
Frank Warmerdam wrote:
> José Vicente Higón wrote:
>> In both cases I was using the latest FWTools release (1.3.4)
>> Why Did I get differents results in MApserver and gdalwarp?Any clue?
> José,
> GDAL does not generally use the PROJ.4 epsg init file.  Instead it has
> a set of .csv files with the EPSG definition information.
> I think you will want to edit this line of FWTools/data/pcs.csv:
> 23030,"ED50 / UTM zone
> 30N",9001,4230,16030,9807,1,0,8805,0.9996,9201,8802,-3,9102,8801,0,9102,8807,0,9001,8806,500000,9001,,,,,,
> To include include the TOWGS84 values.  Something like:
> 30N",9001,4230,16030,9807,1,0,8805,0.9996,9201,8802,-3,9102,8801,0,9102,8807,0,9001,8806,500000,9001,-87,-98,-121,0,0,0,0
> You might want to verify that GDAL is picking up the definition properly
> by entering "testepsg EPSG:23030" in the FWTools shell which will
> report the coordinate system in various forms.  Make sure that one (the
> first I think) includes the proper TOWGS84[] parameters and that they make
> it into the final PROJ.4 rendering.
> Best regards,
