[Gdal-dev] Create Polygon in OGR / C#
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 25 21:52:01 EDT 2007
Jean Michel PIERRET wrote:
> Hi,
> I would like transform a geometry structure in a OGR.Geometry.
> Struct MyGeometry
> bool [] exterior = null;
> int [] partStarts = null;
> int [] partEnds = null;
> double [] padfX = null;
> double [] padfY = null;
> When I use the method ExportToWkt and CreateFromWkt it’s very slow.
> Now I have this method for the transformation :
> Geometry gm = null;
> Geometry g = null;
> Geometry lr = null;
> g = new Geometry(wkbGeometryType.wkbPolygon);
> for (int i = 0; i < partStarts.Length; i++)
> if (exterior[i])
> if (i > 0)
> if (gm == null)
> gm = new Geometry(wkbGeometryType.wkbMultiPolygon);
> gm.AddGeometry(g);
> g.Dispose();
> g = null;
> if (g == null)
> lr = new Geometry(wkbGeometryType.wkbLinearRing);
> for (int j = partStarts[i]; j < partEnds[i]; j++)
> lr.AddPoint(padfX[j], padfY[j], 0);
> g.AddGeometry(lr);
> lr.Dispose();
> lr = null;
> if (gm != null)
> if (g != null)
> gm.AddGeometry(g);
> g.Dispose();
> g = null;
> return gm;
> else
> return g;
> It works but it is not very quick, It’s possible to have a function like
> in the shapelib
> SHPObject SHPCreateObject(ShapeType shpType, int nShapeId, int nParts,
> int[] panPartStart, PartType[] paPartType, int nVertices, double[] adfX,
> double[] adfY, double[] adfZ, double[] adfM);
Jean-michel,
I'm not sure I'd want an all in one function like SHPCreateObject(), but
I think it would be helpful (and easy) to add an AddPoints() or SetPoints()
method for line strings to add a whole array of points in one step. That
would likely help a lot.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
