[Gdal-dev] Reproject with Mapserver vs gdalwarp
Frank Warmerdam
warmerdam at pobox.com
Thu Jul 26 09:16:02 EDT 2007
José Vicente Higón wrote:
> Thank you for your answer,
> I've installed gdal 1.4.0 and I've changed the file
> gdal-1.4.0/share/gdal/pcs.csv, now I have a line like this:
> 23030,"ED50 / UTM zone
> 30N",9001,4230,16030,9807,1,0,8801,0,9102,8802,-3,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,-87,-98,-121,0,0,0,0
> However, I am still getting a wrong reprojected image (shifted over a hundred
> meters). I think the reason is because I am not specifying the nad grid
> shift file ( in my case sped2et.gsb). Am I right?
> How can you specify to gdal for using this kind of file in reprojections?
José,
I'm sorry, I missed your specification of a nadgrids file. Generally it is
bad to specify a +towgs84 parameter and a nadgrid as it isn't absolutely
certain which will be used.
Unfortunately there is no way to update the pcs.csv file to specify a
nadgrid. One thing that might work is to remove the above 23030 line
from pcs.csv, and add the following line at the beginning of
gdal/data/epsg.wkt (make sure this is just one line, not split on
spaces as it likely is in my email):
23030,PROJCS["UTM Zone 30, Northern Hemisphere",GEOGCS["International 1909
(Hayford)",DATUM["unknown",SPHEROID["intl",6378388,297]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-3],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1],EXTENSION["PROJ4","+proj=utm
+zone=30 +ellps=intl +units=m +nadgrids=sped2et.gsb +wktext +no_defs"]]
The "trick" is the EXTENSION["PROJ4","..."] block that tells GDAL/OGR to
use a particular PROJ.4 translation when converting to proj.4 format.
The epsg.wkt file is, I think, consulted if a pcs is not found in the
pcs.csv file so it is important that it be properly removed from there for
this to work.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
