[GDAL-dev] GEOS with GDAL
abhay menon
abhay.menon at gmail.com
Fri Jul 27 04:53:01 EDT 2007
On 7/26/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> abhay menon wrote:
> > Hello all,
> > How do I verify that GEOS compilation is working with my GDAL utility.
> > I have compiled the gdal-1.4.1 with geos-3.0.0-rc4 in vs2003 for some
> > process to build in vc6.
> > OGRPolygon *poPolygon = new OGRPolygon();
> > OGRPoint *pSt = new OGRPoint();
> > when I issue this :
> > 1) int i = poPolygon->PointOnSurface(pSt);
> > result pSt is empty and i = 6.
> > and when I try this :
> Abhay,
> I'm afraid PointOnSurface() is not implemented. It appears to have
> been a "good intention" based on the OGC geometry model I added to
> the api 7-8 years ago and never implemented.
> > 2) int i = poPolygon->Centroid(pSt);
> > it gives me an error and the application quits
> > But when I tried the same with vs2003 the 2) step breaks at getX();
> > 1) step result the same as earlier.
> Hmm. Is pSt a pointer to an existing OGRPoint? I don't know why
> things are crashing but at least this indicates that OGR is trying
> to use GEOS as otherwise it wouldn't do anything - just return
> OGRERR_FAILURE.
> At the core of the Centroid() method is this:
> hOtherGeosGeom = GEOSGetCentroid( hThisGeosGeom );
> OGRPoint *poCentroid = (OGRPoint *)
> OGRGeometryFactory::createFromGEOS( hOtherGeosGeom );
> GEOSGeom_destroy( hThisGeosGeom );
> GEOSGeom_destroy( hOtherGeosGeom );
> if( poPoint == NULL
> || wkbFlatten(poPoint->getGeometryType()) != wkbPoint )
> return OGRERR_FAILURE;
> poPoint->setX( poCentroid->getX() );
> poPoint->setY( poCentroid->getY() );
> delete poCentroid;
> I wonder if the return result (poCentroid) is invalid in
> some fashion that isn't tested for?
> I see the OGR autotests includes this python test:
> g1 = ogr.CreateGeometryFromWkt( 'POLYGON((0 0, 10 10, 10 0, 0 0))' )
> centroid = g1.Centroid()
> g1.Destroy()
> if ogrtest.check_feature_geometry( centroid,
> 'POINT(6.666666667 3.333333333)')
> != 0:
> print 'Got: ', centroid.ExportToWkt()
> return 'fail'
> centroid.Destroy()
> So it seems that Centroid() usually works.
> I guess you will need to debug into the code to try and narrow down
> what is happening. You might want to determine whether other GEOS
> based functions such as Union() work or not. It may be a general problem
> with using GEOS rather than Centroid() specific.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
Hi Frank,
Thanks for the info about PointOnSuface.
But it would be really useful if the GDAL supported the PointOnSurface
function of GEOS as most of the GIS application will creating a Centriod of
a irregular polygon creates point inside the polygon which is not the real
centriod but an output of PointOnSurface or InnerPoint.
Hmm.. about the Centroid part.
I use the build for msvc80 in GEOS trunk to create the MSVC 8 compatible
version which I am able to call in VC++6.
I will let know on the problem that is being created on VC7.1. once I get
time for that. And let you know what happened within.
Best Regards
Abhay Menon
http://abhaymenon.info
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070727/23ed8a5b/attachment.html
