[Gdal-dev] Re: Supported projections/transformation in a GUI
Tomas R
monshi at home.se
Fri Jun 1 09:12:04 EDT 2007
As I thought, no easy way...
If there was, a reply would have found the way to this thread.
Tomas R skrev:
> Ok folks, here is question to crack.
> Simple idea:
> User can pick either a file with geo-data in it or an image without.
> If it is a file without geo-data the user is to be able to select
> which projection/coordinate system the image is saved in and also set
> up the coordinates of the edges of the map. A transformation of
> coordinates between map local projection and WGS84 will the be set up.
> My big problem is the case with no geo-data. I need to set up an
> interface which an ordinary user can use, a user with not to much
> experience of projections and such stuff.
> Firstly I need to sort out which, in GDAL, available projections that
> are common. Just to reduce the list.
> Next I need to find a friendly name to present them with.
> If possible - sort them corresponding to where they are used, for
> example the user can select USA and get all the UTM-zones (and by
> knowing the coordinates of the map select the right zone). Or replace
> USA with a European country and their specific common projections.
> I'm a bit lost, don't know where to start. The ideas above is just
> loose ideas.
> Suggestions? Any tools in GDAL that can help me? Anyway to look up the
> available projections in GDAL? Anyway to sort out the "valid"
> projections?
> Working with GDAL from C#.
> Pls
> /tomas
