[Gdal-dev] Building a customized raster format in ArcGIS 9.2 using
GDAL
Lucena, Ivan
ivan.lucena at pmldnet.com
Wed Jun 6 10:35:09 EDT 2007
Hi all,
Does anybody have ever followed those steps to add a raster format
support in ArcGIS using GDAL?
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Supported_raster_dataset_file_formats
If I understood it correctly, all you need to do is to build a GDAL
library and give it a name like (let’s use GRIB as an example)
gdal_grib.dll or gdal_grib.so, copy it to the ArcGIS's Bin folder and
update "RasterFormats.dat" by adding:
<e on="y" nm="GRIB" ex="*.grib" et="GRIB" at="0x27" />
And then: Vuala! You can display and do all kind of stuff with your new
format.
But it is not working. :-(
I can see the new format in the UI "Tools/Options/Raster/Raster
Formats", but when I try to load images I get:
"Invalid raster dataset. Failed to create raster layer."
I have some experience with the "legacy method" of adding a custom dll
and I thought that this one would be easier. But...
Does anybody have done that before? What is the trick?
Thanks in advance,
Ivan
