[Gdal-dev] Assertion in .tab driver
Mateusz Loskot
mateusz at loskot.net
Fri Jun 15 09:37:42 EDT 2007
Frank Warmerdam wrote:
> Mateusz Loskot wrote:
>> That's one of the reason why old C functions should be replaced
>> with C++ and safe equivalents (see below).
> Folks,
> Well, I don't really agree with this. I have found the C++ templated
> versions of stuff like isspace to be implemented somewhat
> inconsistently between compilers,
Frank,
Do you remember what compilers & versions failed?
> and when things go wrong it is hard to work out why. Just casting an
> argument in problems cases seems fine to me.
OK, but then everytime (in GDAL) a character goes to the isspace() from
<cctype> it should be wrapped with cast, to avoid such problems in future.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
