[Gdal-dev] wrong nodata returned in GDAL dependent software
Christopher Barker Chris.Barker at noaa.gov
Fri Jun 15 14:29:56 EDT 2007
Maciej Sieczka wrote:
 > Hi,
 > Although my GeoTIFF has a value range 0-255 with nodata set to 256 [1],
If it's 8-bit, the largest value possible is 255 -- that may be your
problem.
-CHB
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
