[Gdal-dev] Surfer binary grids support
Ionut Iordache ionut at berkeley.edu
Fri Jun 15 15:07:55 EDT 2007
Greetings,
I'm trying to use GDAL under Solaris 8 to convert Surfer 8 binary grids
(or even ASCII) to ArcInfo floating point grids (.hdr and .flt files).
I don't know whether the Surfer 7 format (GS7BG, advertised as supported
for reading in GDAL) is the same as what Surfer 8 outputs, but I wanted
give it a shot.
My problem is that I can't find support for any of the Surfer grids
formats in the downloaded version of the GDAL 1.4.1.0 source code.
The directory "gdal/frmts/gsg" is simply missing from the source tree
and after compiling and installing from source, "--formats" doesn't list
any Surfer formats as being supported.
So, my question is two-fold:
- what version of the GDAL source code I need to download in order to
get the Surfer driver code, and
- does anyone know if my Surfer 8 binary grids would be readable by the
GS7BG driver ?
Thanks much,
    Ionut Iordache
Dorel Ionut Iordache <diordache at berkeley.edu>
National Center for Airborne Laser Mapping and
Department of Earth & Planetary Science,
University of California Berkeley
Tel: (510) 642-3991 Fax: (510) 643-9980
Address: 371 McCone Hall, Berkeley, CA 94720
http://ncalm.berkeley.edu
http://eps.berkeley.edu
