[Gdal-dev] Copying GCPs from one file to another
Frank Warmerdam
warmerdam at pobox.com
Mon Jun 25 11:55:52 EDT 2007
Ludwig M Brinckmann wrote:
> I have a set of files with GCPs and a set of files that are the result
> of processing the first, which lack the GCPs. The files are GeoTiffs and
> they have the same shape.
> Is there a simple way of getting the GCPs out of the first files and to
> attach them to the other?
> (Simple means simpler than programmatically reading in the georef'ed
> file and the non-georef'ed, extracting the GCPs and rewriting the second
> set, now with GCPs)
Ludwig,
There is no really simple way of doing this.
If I had to do it, I would utilize VRT files. Basically I would:
1) gdal_translate -of VRT original.tif original.vrt
2) gdal_translate -of VRT result.tif result.vrt
3) copy the GCPs section of original.vrt to result.vrt in a text editor.
4) gdal_translate result.vrt result_with_gcps.tif
If you only want to do it a very few times this approach should be ok.
This general approach of using VRT files so that various kinds of metadata
can be copied/modified/etc can be applied to many similar problems.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
