[Gdal-dev] gcore\gdal_rat.cpp typo and logical errors
Lucena, Ivan ivan.lucena at pmldnet.com
Fri Jun 29 09:09:03 EDT 2007
Hi there,
#1 - There is a missing "h" at:
"In the general case each row as a column indicating the minimum pixel"
[http://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdal_rat.cpp#L54]
It looks like someone is imitating my writing style :-), but I guess
that the fix would be:
"In the general case each row has a column indicating the minimum pixel"
#2 - And a missing variable assignment to the returning value of a
function call at:
1239 	        if( iMaxCol == -1 )
1240 	            GetColOfUsage( GFU_MinMax );
[http://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdal_rat.cpp#L1240]
The fix is probably something like that:
1236 	        int  iMaxCol;
1237
1238 	        iMaxCol = GetColOfUsage( GFU_Max );
1240 	            iMaxCol = GetColOfUsage( GFU_MinMax );
1241
1242 	        if( iMaxCol == -1 || nRowCount == 0 )
1243 	            return NULL;
I would be happy to commit it if that is OK.
Best regards,
Ivan
