[Gdal-dev] problem with C# SWIG wrapper
Tamas Szekeres
szekerest at gmail.com
Fri Mar 2 18:21:30 EST 2007
The primary objection of those changes were solely to harmonize the
interfaces created by the Windows and the Linux/OSX builds.
Best regards,
Tamas
2007/3/2, Richard Matsunaga <richard.matsunaga at waypointinfo.com>:
> Tamas,
> The reference problem is gone with the nightly snapshot version of GDAL.
> For reference, I originally tried the latest GDAL release version. I noticed
> that the assembly names have also changed since then, so I guess there has
> been significant work since the last GDAL release.
> Cheers,
> Richard
> -----Original Message-----
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: March 2, 2007 4:51 PM
> To: Richard Matsunaga
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] problem with C# SWIG wrapper
> Would you make the tests with the latest SVN or the nightly build?
> Apparently some of the dll-s might not be available to load for your
> application. You might want use Sysinternals filemon to check which files
> could not actually be loaded.
> 'make test' invokes the application in the same directory as the dependent
> dll-s reside.
> Best regards,
> Tamas
> > Hi all,
> > I've just started using the SWIG-generated C# wrapper and can't get it
> > to work. The build seems to run fine, as do the tests, but when
> > actually trying to use the resulting library, I get the following:
> > System.TypeInitializationException : The type initializer for
> > 'GDAL.gdalconst' threw an exception.
> > ----> System.TypeInitializationException : The type initializer for
> > 'GDAL.gdalconstPINVOKE' threw an exception.
> > 'SWIGExceptionHelper' threw an exception.
> > ----> System.DllNotFoundException : Unable to load DLL
> > 'gdal_gdalconst_wrap': The specified module could not be found.
> > (Exception from HRESULT: 0x8007007E)
> > I get the same error (without the extended info) when I try to run the
> > GDALColorTable.exe that gets created with the build.
> > Is there some config that I must have missed? I think there is a need
> > for a single wiki page for documenting the setup for using the C#
> > wrappers along with common pitfalls.
> > Thanks,
> > Richard
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
