[Gdal-dev] projection with ogr2ogr
Lijian Shi
lijian.shi at und.nodak.edu
Tue Mar 6 11:25:44 EST 2007
I have a shp file of point with longitude, latitude and other attribution.
And I have a geotiff file with the followed information:
Driver: GTiff/GeoTIFF
Size is 256, 256
Coordinate System is:
PROJCS[" Projection Name = Lambert Azimuthal Equal-ar",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",45],
PARAMETER["longitude_of_center",-100],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Now I want to use ogr2ogr to project the shp file in order that the shp file
has the same geoinformation(same projection, same datum) with the geotiff
file. I use the command like:
ogr2ogr -s_srs WGS84 -t_srs EPSG:code utm2.shp point.shp
Am I right? If right, how can I get the code? If wrong, how should I use the
"ogr2ogr"?
Thank you very much!
Lijian
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070306/158ffc19/attachment.html
