[Gdal-dev] Buildbot status report
Mateusz Loskot mateusz at loskot.net
Thu Mar 8 04:07:30 EST 2007
I cleaned up the buildbot instance and all builders should work
well now. Here is list of issues left to solve:
1. telascience and smokey
- WCS tests (wcs_4) fail
2. epimetheus
a) - run_all.py throws following error:
File
"/Data/buildbot/osgeo/slaves/gdal/epimetheus-full/build/gdal/pymod/gdal.py",
line 193, in ?
    from _gdal import ptrcreate, ptrfree, ptrvalue, ptrset, ptrcast,
ptradd, ptrmap, ptrptrcreate, ptrptrvalue, ptrptrset
ImportError: cannot import name ptrcreate
http://buildbot.osgeo.org:8500/epimetheus-full/builds/151/step-test/0
b) make in swig/csharp throws following error:
make: execvp:
/Volumes/Data/buildbot/osgeo/slaves/gdal/epimetheus-full/build/gdal/libgdal.la:
Permission denied
http://buildbot.osgeo.org:8500/epimetheus-full/builds/151/step-csharp-make/0
Frank is going to fix the 1st issue.
Hobu, do you have an idea what is the problem in 2.a) ?
Tamas, would you have any suggestion about how to fix 3.b) ?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
