[Gdal-dev] Buildbot status report
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 8 18:20:24 EST 2007
Mateusz Loskot wrote:
>> This problem is related to the libtool builds that I'm not too
>> familiar with. I'll have to look after someone who can tell me how to
>> support building of shared libraries using libtool. Currently when
>> using the libtool option, -shared or -dynamiclib is not assigned to
>> $(LD_SHARED) so the compilation fails.
> Tamas,
> Yes, I understand it. I'm not sure why GDAL does not use any of
> these flags.
> Frank, may be we could add it if it helps?
Mateusz,
My (vague) understanding was that the Java bindings are not using
libtool in the conventional fashion and that this causes some problems.
Perhaps I am wrong.
Earlier I suggested that support for Java on buildbot was low priority,
which I still consider to be the case. But I would like you to help
to ensure that Java building works smoothly on Linux and win32 platforms
if you can.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
