[Gdal-dev] compilation of GDAL/OGR-132 with DGNDirect09964
    Jean-Daniel Gonon
    jdgonon at gi-lemans.com
    Wed Mar 14 10:13:46 EDT 2007
Hi
I have a new question about compilation of GDAL/OGR-132 with
DGNDirect09964 :
When I compile in debug mode, I have much warnings like this :
"dgntkMD8d.lib(CFontMgr.obj) : warning LNK4204:
'd:\DGN_V8\GDAL-OGR\gdal132_vc8\VisualStudio8\gdal\Debug_DLL\vc80.pdb'
is missing debugging information for referencing module; linking object
as if no debug info"
In debug mode, I use debug DLL (libpng13d-vc8.lib libjpegd.lib
zlib1d-vc8.lib xerces-c_2D.lib dgntkMD8d.lib olessMD8d.lib zlibMD8d.lib)
and parameter "C/C++ => Code generation => Runtime Library" is
"Multi-threaded Debug DLL (/MDd)" (see gdal_debug.vcproj project file in
attached file).
Also, when I compile in release mode, i have errors like this :
"tif_aux.obj : error LNK2001: unresolved external symbol __RTC_Shutdown"
In release mode, I use release DLL (libpng13-vc8.lib libjpeg.lib
zlib1-vc8.lib xerces-c_2.lib dgntkMD8.lib olessMD8.lib zlibMD8.lib) and
parameter "C/C++ => Code generation => Runtime Library" at
"Multi-threaded DLL (/MD)" (see gdal_release.vcproj project file in
attached file).
I don't know what I must to do to correct these problems...
I don't know if my question is comprehensible, but I need your help...
Thanck you in advance.
Jean-Daniel
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070314/58ad1074/attachment.html
