[Gdal-dev] SWIG Exceptions for C# Bindings
Simon Perkins
sy at perkins.net
Thu Mar 15 23:28:12 EDT 2007
Can someone remind me how error reporting works with the GDAL and OGR C#
bindings? Do errors typically throw exceptions, or return status codes,
or nulls, or both? There seems to be code to throw exceptions in most of
the method definitions, but the code in swig/csharp/apps often appears
to be checking for return null values instead. Which is correct?
For instance, if OGR.DataSource.GetLayerByIndex() is invoked with an
invalid index, or if something else goes wrong, do we always/sometimes
get an exception or do we just get a null back? Is there a general policy?
Cheers,
Simon
