[Gdal-dev] OGR PostGIS driver problems on x86_64
Edzer J. Pebesma
e.pebesma at geo.uu.nl
Fri Mar 23 05:21:36 EDT 2007
I'm running debian testing ("etch") on a x86_64 architecture; when I run
ogr2ogr -overwrite -f "PostgreSQL" "PG:dbname=postgis" meuse.shp
it gives me a segmentation fault. A stack trace is
0x00002aaacf4b25b0 in strlen () from /lib/libc.so.6
(gdb) bt
#0 0x00002aaacf4b25b0 in strlen () from /lib/libc.so.6
#1 0x00002aaacf4844bc in vfprintf () from /lib/libc.so.6
#2 0x00002aaacf4a472a in vsnprintf () from /lib/libc.so.6
#3 0x00002aaacd6af5e5 in CPLString::vPrintf () from
/usr/lib/libgdal1.3.2.so.1
#4 0x00002aaacd6af80c in CPLString::Printf () from
#5 0x00002aaacd7565d7 in OGRPGTableLayer::CreateFeatureViaInsert ()
from /usr/lib/libgdal1.3.2.so.1
#6 0x0000000000401b83 in ?? ()
#7 0x00000000004023f5 in ?? ()
#8 0x00002aaacf45c4ca in __libc_start_main () from /lib/libc.so.6
#9 0x00000000004017aa in ?? ()
#10 0x00007fffdd741158 in ?? ()
#11 0x0000000000000000 in ?? ()
when I repeat this on an otherwise identical i686 (32 bits)
architecture, no problems. I found this out when trying to write PostGIS
data directly from R, using the rgdal interface.
Is this a known problem? How can I (help to) resolve this?
A related but less serious issue is that the layer name is ignored: on
the 32 bits architecture
ogr2ogr -overwrite -f "PostgreSQL" "PG:dbname=postgis" meuse.shp mmm
will not add a table; after removing mmm table meuse will be written,
after renaming the shapefile into mmm.shp (etc) mmm will be written. A
layer name different from the shapefile name causes it not to be
written; no layer name will result in the shapefile name being written.
Is this documented behaviour?
Edzer
