[Gdal-dev] gdaladdo throwing errors
William Kyngesburye
woklist at kyngchaos.com
Sun Mar 25 02:24:58 EDT 2007
I have a very similar bug for this, which was fixed - the problem is
actually in libtiff (your errors are slightly different):
http://bugzilla.remotesensing.org/show_bug.cgi?id=1204
You need to build libtiff from CVS to get this fix.
I see that you are on OSX (from your bug report) - have you tried my
framework builds? I ran my gdal_translate, tiffcp and gdaladdo on
your huge test tiff with no errors.
On Mar 24, 2007, at 10:37 PM, Seth Price wrote:
> I'm having a problem with gdaladdo, I'm afraid we don't seem to be
> getting along. It's very sensitive about the levels specified. For
> example, if I specify "2 4 6 12 24 48 96" for a 21600x21600px image
> it works, but if I specify "2 4 8 16 32" it throws many errors.
> I can normally find a set of levels that works via guessing, but
> that isn't going to work any longer. Does anyone have any idea how
> I can work around these errors? I haven't been able to find a
> pattern. Fixing the problem would be better.
> You can download the file that I've been using for a test here:
> http://pricepages.org/temp/N048W123_x1_GLC.tif.gz (19MB)
> I think you can ignore the "StripByteCounts" warnings. I'm fairly
> sure that they are related to this bug. (It would be nice if
> someone could have a look at that also, but it's not urgent.):
> http://bugzilla.remotesensing.org/show_bug.cgi?id=1483
> Here are some examples of the behavior that I'm talking about:
> $ /usr/local/bin/gdal_translate test.tif test.2.tif
> Warning 1: TIFFReadDirectory:test.tif: Wrong "StripByteCounts"
> field, ignoring and calculating from imagelength
> Input file size is 21600, 21600
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> $ /usr/local/bin/gdaladdo -r nearest test.2.tif 2 4 8 16 32
> 0.Warning 1: TIFFReadDirectory:test.2.tif: Wrong "StripByteCounts"
> ERROR 1: test.2.tif:DumpModeDecode: Not enough data for scanline 0
> ERROR 1: TIFFReadEncodedTile() failed.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 2
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 2
> $ ./gdaladdo -r nearest test.tif 2 4 6 12 24 48 96
> Any ideas on where to proceed next with this?
> Thanks for any help,
> Seth
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
