[Gdal-dev] GDAL with VB.net (VS 2005 Express)
Tamas Szekeres
szekerest at gmail.com
Wed Mar 28 19:19:57 EDT 2007
Milo,
I guess it might be a visual basic related issue since when doing the
same in C# the array size is not altered. AFAIK, VB uses 1 based
arrays so it might allocate the array with size+1 by default. However
I will try this if I have time.
Best regards,
Tamas
2007/3/28, Milo van der Linden <milo at 3dsite.nl>:
> Hello Tamas and Frank,
> Again thank you for the responses! I pretty much figured things out, but I
> still don't know why I get an array of 4 doubles returned from the
> TransformPoint function, can it be that the return values are:
> X, Y, relative-height between fromEllipsoide - toEllipsoide, absolute
> height?
> I also found out that the way the developers at MapWindow implemented this
> is not correct, they do not take action on the towgs84 when the source
> ellipsoid is different from the target ellipsoid. They also work only with
> shape files, which I think is a missed change with the wonderful generic
> options that ogr offers!
> Right now I use the fourth value in the array as my Z-value, because it
> seems to represent absolute height, since I drape my layer on the terrain in
> GoogleEarth, this is appropriate enough. Attached you will find a small
> sample file in kml format. If you load it in Google Earth, you will see the
> shift.
> Here is a (VB.net) code snippet (put a reference in your project to
> ogr_csharp, no other references are needed):
> 'Add the next lines in the top of the module:
> Imports OGR
> Imports OGR.ogr
> 'In the calling subroutine, I open a GIS layer with Ogr.ogr.open:
> ds = OGR.ogr.Open(sFile, 0)
> Dim drv As OGR.Driver = ds.GetDriver()
> For j = 0 To ds.GetLayerCount - 1
> Dim lyr As Layer = ds.GetLayerByIndex(j)
> Dim RDproj4 = "+proj=stere +lat_0=52.156160556
> +lon_0=5.387638889 +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel
> +towgs84=593,26,478,0,0,0,0 +units=m +no_defs"
> Dim WGS84proj4 As String = "+proj=longlat +ellps=WGS84
> +datum=WGS84 +no_defs"
> 'Get the source SpatialReference from the layer
> Dim sr1 As SpatialReference = lyr.GetSpatialRef
> 'Create the destination Spatialreference for GoogleEarth
> Dim sr2 As New SpatialReference("")
> sr2.ImportFromProj4(WGS84proj4)
> 'I can call my TransFormPoint Function in 2 ways:
> result = TransFormPoint(sr1, sr2, myPnt)
> 'or
> result = TransFormPoint(RDproj4, WGS84proj4, myPnt)
> 'the Point is in an internal Geometry class, not the ogr geometry class.
> 'both methods give the exact same result, and it seems to be the right
> result! There is still a shift when presenting the results in Google Earth,
> but this can also be because the imagery is shifted, I am in contact with
> Aerodata in order to get the answer whether the image-shift is there on
> purpose.
> 'I use two constructors for the TransformPoint:
> Public Function TransformPoint(ByVal srcSR As SpatialReference, ByVal dstSR
> As SpatialReference, ByVal pnt As Geometry.Point) As Geometry.Point
> 'Reads the SpatialReference from the source GIS file
> Dim tPnt As New Geometry.Point
> Dim ct As CoordinateTransformation
> '/* making the transform
> ct = New CoordinateTransformation(srcSR, dstSR)
> Dim p(3) As Double
> p(0) = pnt.x
> p(1) = pnt.y
> p(2) = pnt.z
> ct.TransformPoint(p)
> Debug.Print("x:" & p(0) & " y:" & p(1) & " z:" & p(3))
> 'The Z value has to remain relative to the terrain
> tPnt.x = p(0)
> tPnt.y = p(1)
> tPnt.z = p(3)
> 'tPnt.z = pnt.z
> Return tPnt
> End Function
> Public Function TransformPoint(ByVal src As String, ByVal dst As String,
> Dim dstSR As SpatialReference
> Dim srcSR As SpatialReference
> '/* Initialize srs
> srcSR = New SpatialReference("")
> srcSR.ImportFromProj4(src)
> Debug.Print("SOURCE IsGeographic:" & srcSR.IsGeographic().ToString
> & " IsProjected:" & srcSR.IsProjected().ToString)
> dstSR = New SpatialReference("")
> dstSR.ImportFromProj4(dst)
> Debug.Print("DEST IsGeographic:" & dstSR.IsGeographic().ToString &
> " IsProjected:" & dstSR.IsProjected().ToString)
> Dim p(3) As Double
> p(0) = pnt.x
> p(1) = pnt.y
> p(2) = pnt.z
> tPnt.x = p(0)
> tPnt.y = p(1)
> tPnt.z = p(3)
> 'tPnt.z = pnt.z
> Return tPnt
> End Function
> Tamas Szekeres schreef:
> Milo,
> I wonder why you have run into this issue. TransformPoint will not
> alter the length of that array.
> Would you post a sample to reproduce this problem?
> Best regards,
> Tamas
> Another thing:
> The Transformpoint function takes an array of doubles. I input an array
> of 3 values (x,y,z) and it returns 4 values. What do the four return
> values mean?
