[Gdal-dev] Make error "libtool: compile: unable to infer tagged
configuration"
Patton, Eric
epatton at nrcan.gc.ca
Fri Mar 30 11:54:04 EDT 2007
I just upgraded my Ubuntu to 7.04 Beta, and I'm re-compiling gdal-1.4.0. configure progresses cleanly with no obvious errors. At the very beginning of make, however, I encounter this error:
$ sudo make
(cd port; make)
make[1]: Entering directory `/usr/local/gdal-1.4.0/port'
/bin/sh /usr/local/gdal-1.4.0/libtool --mode=compile g++ -DOGR_ENABLED -I/usr/local/gdal-1.4.0/port -c -o cpl_conv.o cpl_conv.cpp
libtool: compile: unable to infer tagged configuration
libtool: compile: specify a tag with `--tag'
make[1]: *** [cpl_conv.o] Error 1
make[1]: Leaving directory `/usr/local/gdal-1.4.0/port'
make: *** [port-target] Error 2
Any ideas on what this error means and how to correct it?
Thanks,
~ Eric.
