[Gdal-dev] GDALWarpOptions padfSrcNoDataImag
Craig Miller
craig.miller at spatialminds.com
Wed May 2 18:27:37 EDT 2007
Thanks Frank.
Sure, I'll verify the warp works with that fix then file the bug.
Craig
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Wednesday, May 02, 2007 3:21 PM
To: Craig Miller
Cc: Gdal-Dev
Subject: Re: [Gdal-dev] GDALWarpOptions padfSrcNoDataImag
Craig Miller wrote:
> I'm getting an exception in GDALWarpOperation when I initialize with
> my warp options. The exception is getting thrown when Initialize
> verifies that padfSrcNoDataImag[0] isn't 0 since padfSrcNoDataImag is
> NULL. I can of course tweak gdal to check for a NULL pointer instead
> of looking for 0 in the 0 index, but without digging further I'm not
> 100% that is ok. I've processed several hundred files with my code
> the way it is, and it is only this new image that is giving me fits so
> I thought I'd first try and determine what the padfSrcNoDataImag
> option is. With a cursory look at the docs I haven't been able to find a
description of how/why this gets set.
> Any suggestions?
Craig,
I don't know why this would only affect one image out of many similar ones.
But I do think this code in Initialize() should not assume padfSrcNoDataImag
is non-NULL just because padfSrcNoDataReal is non-NULL
if( hSrcBand != NULL
&& psOptions->padfSrcNoDataReal != NULL )
int bMergeSource = FALSE;
if( psOptions->padfSrcNoDataImag[iBand] != 0.0
&& !GDALDataTypeIsComplex( psOptions->eWorkingDataType
bMergeSource = TRUE;
Could you file a bug on this, and I'll fix it in trunk and 1.4 branch. I
think the fix would be to change:
to:
if( psOptions->padfSrcNoDataImag != NULL
&& psOptions->padfSrcNoDataImag[iBand] != 0.0
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
