[Gdal-dev] Unable to load PROJ.4 library in GDAL
Roger André
randre at gmail.com
Thu May 3 13:40:08 EDT 2007
I'm having problems with the GDAL installation I have running in Cygwin on
Windows XP. It appears that GDAL is unable to find some of the proj
libraries that it needs. I ran the following command:
gdalwarp -s_srs "EPSG:32651" -t_srs "EPSG:4326" input.tif output.tif
it gave this error when it ran:
ERROR 6: Unable to load PROJ.4 library (libproj.dll), creation of
OGRCoordinateTransformation failed.
I did a search and found posts saying that I should download and install
proj from source, then compile GDAL with static linking to proj using the
"--with-static-proj4" configure flag. I downloaded and installed
proj-4.5.0from source yesterday, but am unsure what path to give the
"--with-static-proj" option.
Can someone give me a few pointers about what I should look for?
Thanks,
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070503/e2161506/attachment.html
