[Gdal-dev] GeoTiff pixel resolution interpretation with gdalinfo
mattia
mattia.parigiani at gmail.com
Thu May 3 14:15:56 EDT 2007
Yes, what I need is to "resize" the pixel. Being the image taken from the
satellite, it skews the far away pixels, mainly ones towards the edges of
the bounding box. I need to execute a bow-tie correction, then somehow
"compress" the pixels to a square resolution. Does that sound feasable? I
will try the command.
Cheers
Mattia
On 5/3/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> mattia wrote:
> > Coordinate System is:
> > PROJCS["HDFLook: LINEAR",
> > GEOGCS["unnamed",
> > DATUM["unknown",
> > SPHEROID["unnamed",6370997,0]],
> > PRIMEM["Greenwich",0],
> > UNIT["degree",0.0174532925199433]],
> > PROJECTION["Equirectangular"],
> > PARAMETER["latitude_of_origin",0],
> > PARAMETER["central_meridian",0],
> > PARAMETER["false_easting",0],
> > PARAMETER["false_northing",0],
> > UNIT["metre",1,
> > AUTHORITY["EPSG","9001"]]]
> > Origin = (8912408.472916,7090227.412053 )
> > Pixel Size = (694.49452741,-1000.15538912)
> > Is my interpretation correct? The pixel resolution as indicated is in
> > meters... Accordingly 694 meters horizontally (X res) , 1000 meters
> > vertically (Y res)?!?!
> Mattia,
> That is correct.
> > What is the minus sign i front of the Y res for???
> It means that as you step "down" the image from the top left corner you
> subtract 1000m per pixel step from the y coordinate. This is normal.
> > What is the UNIT["degree",0.0174532925199433]], factor in this output??
> > can I use it to define the resolution?? Or what is it needed for??
> This indicates that one degree on the underlying geographic
> coordinate system is 0.017... radians. It is standard and does
> not help you for what you want to do.
> > Final question,
> > Is there a stright forward way of changing the image's resolution so as
> > to have a quadratic one whereby resX=resY ????
> I didn't follow that I'm afraid. Are you just wanting to resample
> your image to have square pixels? You could do something like:
> gdalwarp -rb -ps 694 694 Area1.tif Area1SquarePixels.tif
> This would use a bilinear resampling kernel to convert your
> image from 694x1000 meter pixels to 694x694 meter pixels.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070503/ce1d2285/attachment.html
