[Gdal-dev] Memory Leak with SpatialReference class in C# bindings
Tamas Szekeres szekerest at gmail.com
Fri May 4 18:01:31 EDT 2007
Jason,
I've applied the fix for the memory leak problem in the SVN trunk and
branch 1.4. Would you mind making your test using the latest SVN
version?
Best regards,
Tamas
2007/5/4, Jason Beverage <jbeverage at prologic-inc.com>:
> All,
> I've been looking at the C# bindings to see if we can use them in our
> project and I noticed that there seems to be a memory leak when using
> the SpatialReference class.  I'm not sure this same problem exists
> elsewhere, but it is something to look into.
> Running the following simple loop makes memory go through the roof even
> though Dispose is being called
> for (int i = 0; i < 1000000; ++i)
>   using (SpatialReference dst = new SpatialReference(""))
>     //Do something with SpatialReference
> I looked through the bindings quickly this morning and didn't see
> anything glaringly obvious, should I file a ticket for this problem?
> Thanks!
> Jason
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
