[Gdal-dev] EPSG code of 32618 for WGS 84 / UTM zone 18N
Maciej Sieczka tutey at o2.pl
Sat May 5 04:10:42 EDT 2007
John Mitchell wrote:
> Hi,
> I have the listed the gdalinfo listing of an erdas imagine file below and
> notice that it does not have a EPSG code within it.  I need this EPSG code
> if I want to reproject within gdalwarp or for on the fly projection within
> mapserver.  Based the gdalinfo listing I searched within the epsg file and
> found the following code and definition:
> # WGS 84 / UTM zone 18N
> <32618> +proj=utm +zone=18 +ellps=WGS84 +datum=WGS84 +units=m +no_defs  <>
> Does the above EPSG code of 32618 make sense for the below gdalinfo
> listing?
Do "epsg_tr.py 32618" and compare.
Maciek
