[Gdal-dev] GDALWarp reverting to Nearest resampling (solved)
Seth Price
seth at pricepages.org
Sat May 5 13:19:40 EDT 2007
And it was a bug in my program. Sorry for filling your inbox!
~Seth
On May 5, 2007, at 11:35 AM, Seth Price wrote:
> I'm trying to distribute gdalwarp as cluster jobs. This involves
> copying gdal and it's libraries to remote machines, running the
> commands, and returning the output. I'm having trouble with
> gdalwarp; the '-rcs' flag isn't taking effect for some reason.
> No error is being returned and it's taking the appropriate amount
> of time for the 'nearest' algorithm. The exact command will look
> like this:
> ./gdalwarp -t_srs '+proj=merc +datum=WGS84 +units=m' -ts 11651
> 34151 -wm 200 -co 'TILED=YES' -co 'BLOCKXSIZE=512' -co
> 'BLOCKYSIZE=512' -rcs './N072W180_x1.tif' 'out.tif'
> When I tried running this command outside of its wrapper program,
> it worked as expected.
> Does anyone have any idea what could cause the sampling method to
> default? I've browsed the source code, and nothing stands out as a
> potential problem. Were there any recent bugs fixed that may be
> related? Do any environment variables need to be set?
> I'm using a recent CVS of GDAL, because 1.4.1 wouldn't compile. I'm
> on a Mac.
> Thanks,
> Seth
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
