[Gdal-dev] Expose Array Based Coordinate Transformation Methods
in CoordinateTransformation (#1615)
Frank Warmerdam
warmerdam at pobox.com
Sun May 6 15:46:34 EDT 2007
Tamas Szekeres wrote:
> Hi All,
> I had a first crack at adding CoordinateTransformation.TransformPoints
> to the SWIG interface to provide the transformation of the given
> number of points passed as arrays of coordinates.
> I've tested the code for the C# bindings and worked pretty well. If
> someone have further issues please give me a comment at:
> http://trac.osgeo.org/gdal/ticket/1615
Ari,
It seems the perl bindings are no longer building since Tamas' change.
I see:
gcc -c -I../../gcore -I../../alg -I../../ogr -I../../port -D_REENTRANT
-D_GNU_SOURCE -DDEBUGGING -fno-strict-aliasing -pipe -I/usr/local/include
-D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -O2 -g -pipe
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -m32 -march=i386 -mtune=pentium4
-fasynchronous-unwind-tables -DVERSION=\"0.21\" -DXS_VERSION=\"0.21\" -fPIC
"-I/usr/lib/perl5/5.8.6/i386-linux-thread-multi/CORE" osr_wrap.cpp
osr_wrap.cpp: In function 'void
_wrap_CoordinateTransformation_TransformPoints(PerlInterpreter*, CV*)':
osr_wrap.cpp:8406: error: '$dim0' was not declared in this scope
osr_wrap.cpp:8407: error: size of array 'argout4' has non-integral type '<type
error>'
osr_wrap.cpp:8408: error: size of array 'argout5' has non-integral type '<type
error>'
osr_wrap.cpp:8414: error: 'argout3' was not declared in this scope
make[1]: *** [osr_wrap.o] Error 1
make[1]: Leaving directory
`/osgeo/buildbot/gdal/buildslave/telascience-full/build/gdal/swig/perl'
Any help getting this working again would be appreciated.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
