[Gdal-dev] RFC 12: Improved File Management
Tamas Szekeres
szekerest at gmail.com
Mon May 7 17:46:19 EDT 2007
Frank,
Oops. We've indeed Driver.Delete as you've mentioned that is surely be
responsible to remove the underlying files in the filesystem. In this
regard the Rename and Move functionality would also be required at the
SWIG interface. At this time exposing the CPL/VSI low level file
operations would not be so benefical.
Best regards,
Tamas
2007/5/7, Frank Warmerdam <warmerdam at pobox.com>:
> Tamas Szekeres wrote:
> > Frank,
> > I like this idea, along with RFC-11 will be a great addition. Wouldn't
> > it be possible that the whole set of Rename/Move/Delete operations
> > was exposed to the SWIG interface by default?
> Tamas,
> The RFC calls for the RenameDataset being exposed through SWIG, and I
> see that the Delete operation for datasets is already available through
> SWIG.
> Are you perhaps referring to the lower level CPL/VSI file operation
> functions?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
