[Gdal-dev] Gdalwarp - corrupt merge
Craig Miller
craig.miller at spatialminds.com
Mon May 7 18:22:24 EDT 2007
When using gdalwarp on paletted geotiffs that have "TILED=YES" and
"COMPRESS=LZW" set during creation I'm running into a couple of problems. I
confirmed via gdalinfo that all input files have the projection defined as
EPSG:4326.
Problem #1
Gdalwarp existing_file1.tif existing_file2.tif corrupts the second image.
Projection is stripped, and none of my apps (non-gdal) can read the image
(E.g. global mapper). gdalinfo shows the projection being stripped, still
paletted image. Any suggestions on how to merge two geotiffs in this
format?
Problem #2
gdalwarp -te xmin ymin xmax ymax infile.tif outfile.tif
Outputfile has no projection defined, compression is lost, and I assume
tiling is too.
Everything works ok if I specify -co options, -s_srs, -t_srs, etc but I
thought it was supposed to output everything the same as the input.
Craig Miller
www.spatialminds.com
