[Gdal-dev] problem abotu reprojection with ogr2ogr
Lijian Shi
lijian.shi at und.nodak.edu
Tue May 8 14:02:12 EDT 2007
Hi, everyone,
I have a shp file and landsat data of the same field, but these data's
projections are different. The projection information of shp file is below:
GEOGCS["GCS_Assumed_Geographic_1",DATUM["D_North_American_1927",SPHEROID["Cl
arke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0
174532925199433]]
We can get this information from .prj file or use command 'ogrinfo' .
The projection information of landsat data is:
PROJCS["WGS 84 / UTM zone 14N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-99],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32614"]]
I copy this information into a empty file, then saved as 'landsat.prj'.
Now I use 'ogr2ogr' to reproject the shp file in order that the shp file has
the same projection information with landsat data. The command is as below:
ogr2ogr -s_srs input.prj -t_srs landsat.prj output.shp input.shp
When I put the output.shp and input.shp into ArcGIS together, there a shift
between two file. Dose anyone know the reason? Is there any problem with my
command?
Thanks in advance.
Lijian
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070508/3516dae4/attachment.html
