[Gdal-dev] Re: Problem using EPSG in C#
Tomas R monshi at home.se
Wed May 9 11:37:47 EDT 2007
Tomas R skrev:
> Tamas Szekeres skrev:
>> Tomas,
>> Thank you for the detailed analysis of the problem. I'm working on
>> this issue and will notify you if I have further information. In the
>> meantime I would suggest to submit a ticket including the example
>> code.
>> http://trac.osgeo.org/gdal/newticket
>> Best regards,
>> Tamas Szekeres
> Ok, done that. Included as specific info as I could.
> You should be able to reproduce it.
> Thanks
> Tomas
For those interested the ticket number is 1621. Just click the link to
read the ticket:
http://trac.osgeo.org/gdal/ticket/1621
Hope this will be solved sometime soon. I have other things to attack in
my code so just knowing this is under review is, for now, good enough
for me.
/Tomas
