[Gdal-dev] Shapefile with hole touching : fix?
Frederic Claudel frederic.claudel at magellium.fr
Fri May 11 07:58:22 EDT 2007
FYI, we submitted a fix in Trac for bug #1415, but it isn't marked as fixed
so I'm also posting here.
Can someone else test the fix?
http://trac.osgeo.org/gdal/ticket/1415
The bug also appeared when writing a shapefile with two outer rings touching
each other on one of their starting vertices.
Regards,
Frederic Claudel
Magellium
