[Gdal-dev] OCI support for Oracle 9i
Mateusz Loskot
mateusz at loskot.net
Tue May 15 07:47:26 EDT 2007
Otto Dassau wrote:
> Hi,
> I am trying to build gdal 1.4.1 with OCI support but with no success. The
> database is an oracle 9i. In the configure script I provide:
> --with-oci=/usr/lib/oracle/9.2.0/OraHome \
> --with-oci-lib=/usr/lib/oracle/9.2.0/OraHome/lib
Otto,
You should use
--with-oci
*or* pair of options
--with-oci-include
--with-oci-lib
The single --with-oci is equivalent to ORACLE_HOME environment,
but it may not work well with older Oracle versions, because there were
some changes in structure of installation directory.
So, try to use the two latter options.
> There are two problems:
> a) checking for Oracle OCI headers in /usr/lib/oracle/9.2.0/OraHome/rdbms/public
> During configuration the header files are assumed to be in rdbms/public:
> ... checking for Oracle OCI headers in
> but in my oracle installation the header files are located in /rdbms/demo/, so I
> have to copy them. Can I somehow add:
> --with-oci-include='/usr/lib/oracle/9.2.0/OraHome/rdbms/public /usr/lib/oracle/9
> .2.0/OraHome/rdbms/demo' ?
Yes, you should use --with-oci-include.
> b) checking for Oracle OCI libraries in /usr/lib/oracle/9.2.0/OraHome/lib
> here I get following error message that -lnnz10 is missing:
> #configure:26066: checking for Oracle OCI libraries in
> #/usr/lib/oracle/9.2.0/OraHome/lib configure:26097: g++ -o conftest -g -O2
> #-I/usr/lib/oracle/9.2.0/OraHome/rdbms/public
> #-L/usr/lib/oracle/9.2.0/OraHome/lib -lclntsh -lnnz10 conftest.cc -L/usr/lib
> #-lxerces-c -lpthread -ljasper -lmfhdf -ldf -lgif -ljpeg -ltiff -lpng -lnetcdf
> #-lcfitsio -lpq -L/usr/lib -lpq -lz -lpthread -lm -lrt -ldl >&5 /usr/bin/ld:
> #cannot find -lnnz10 collect2: ld returned 1 exit status
> #configure:26103: $? = 1
> #configure: failed program was:
> #| /* confdefs.h. */
> I haven't found anything about it in other mailings, so I hope someone can give
> me a hint, how I can manage to get oracle support for current gdal 1.4.1. I
> worked with version 1.3.2 before and there I have oci support with the same
> configuration.
Could you give me list of libraries in your directory
Cheers
Mateusz Loskot
http://mateusz.loskot.net
