[Gdal-dev] open files from mysql
Frank Warmerdam
warmerdam at pobox.com
Tue May 15 13:45:51 EDT 2007
Emanuele Conti wrote:
> Hi and thanks for your fast reply,
> I'm concerned that this is a rather specialized driver, and that
> folks might
> actually want to use rasters from MySQL in a variety of other ways
> as well.
> Can you give me an example? I can't imagine (I'm not so expert in gis
> maps) how a raster map could be stored in a mysql db other than the one
> of storing the whole file in a blob...
Emauele,
Well, another approach is to treat a large image as a set of tiles. So
a table might represent the image, and each row is a tile with other
columns holding the bounds for instance.
> I would be happy to have the driver put in "spike" (an experimental
> area) in
> subversion, but I'm not yet all that comfortable that this makes
> sense as
> *the* mysql raster driver for GDAL.
> How should I do that? And how could this first "idea" of driver be
> improved? I could work on it if only I'd have some feedback about the
> direction it should go and if I'm pretty sure that it won't be wasted time!
If you submit the driver via Trac, I can commit it on the spike.
Then I'd encourage you to write up a topic about the driver in the wiki
for folks to look at if they want to try it. I'll add a bit of info there
on how to pull it out of spike into an existing build. Likely we would
handle it as a plugin.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
