[Gdal-dev] creating tiles from rasters using gdal
Christopher Barker Chris.Barker at noaa.gov
Tue May 15 13:56:31 EDT 2007
Paul Spencer wrote:
> I need to turn some rasters (png and tiff) into tiles for use in a tiled
> map application.  For various reasons, these rasters are not
> georeferenced and I don't need them to be.
if you don't need them geo-referenced, then you can use regular old
image processing tools. ImageMagick, for instance, should be able to do
that just fine.
There was a note about that on list list not too long ago.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
